Results 1 to 4 of 4
Thread: 206 TSI - Anybody track their 206? What upgrades?
    Jun 2021
    Having come from an Golf mk7R into an 206TSI, does anybody have any good information on what upgrades should be done?
    I've pulled a few things off my Golf R before I sold it and installed on the passat:
    - DBA T3 Rotors
    - Intima Type D pads
    - Rs3 Brake ducts
    - Put in fresh Castrol SRF fluid
    - Dogbone mount
    - K&N panel filter + remove snow grate
    - Currently running S001 (non-RFT version) on the 19's, I have 18 inch semi slicks, but they are 225/40/18, too small for the passat. Anybody had luck running 225/40/18? It would only be on the track
    - 034 Motorsport stage 1 ECU + DSG tune
    Planning to go Sandown next month.
    I can definitely feel the extra weight/length of the passat and I don't know how it will hold up on the track compared to the golf. It's less pointy (but not much), there is quite a bit more body roll.
    Should I just bite the bullet and get camber plates (-1.5 camber) + rear sway bar? I'm afraid the car will be too soft for the track
    Feb 2014
    I added front+rear sway bars to the Arteon and that made a big difference to the body roll - it was pretty bad, even compared to the R36 ( which is a similar size). I haven't tracked it though, so probably not the best source of advice.
    IMO - 225 tires are quite small for a 206 Passat. The Arteon runs 245 standard and even then traction is an issue with a stage 2 tuned ea888.3 "206tsi" engine (and gearbox) - been exploring options for wider tires.
    Jun 2021
    Thanks for the reply, which front and rear sway bars did you go for?
    Also funnily enough a family member came with me to a track day and he had his stage 1 Arteon (white) - Cars - Tampered Motorsport - 15th May 2022 - Tampered Motorsport Sandown - Group A - Motorsport - SDpics
    The body roll looked pretty controlled for how big it is (completely stock except brakes and tune), I think the 20 inch rims helped quite a bit. He was also only 2-3s a lap off my Stage 2 Mk7R - I need a driver mod lol
    Yeah 225/40/18 seem like they're going to be too skinny for a passat/arteon size, but annoyingly the semi slicks only have 2 track days on them
    Feb 2014
    Nice =)
    I got the sway bars (and pretty much everything else) from Harding Performance in Brisbane. You should be able to access details and links here: Arteon Performance Mods / Tuning (let me know if you have any issues)
