Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2021 passat 206 rline downpipe with cat noise
    Feb 2022
    Auckland, New Zealand
    Quote Originally Posted by Bless_you View Post
    Oh and is a mk7 golf r the downpipe fitment i need? Or do I need to source a special passat one?
    Golf R ones fit. If you have a wagon you may need a 40mm adapter however I did not need one for my wagon. Straight fit from a Golf 7 R CTS turbo catted downpipe (200 cell cat)
    2018 B8 Black 206TSi Estate - Thule Roof Racks - Tow bar - Dechrome - REVO Stg1 ECU/TCU - R600 Intake - CTS turbo muffler delete - CTS inlet pipe - CTS 200 cell catted downpipe w/ OEM resonator delete
    2009 B6 Black 2.0TSi Estate
    Follow my instagram for the build @rogs_passatb8 (if... you wanna...)
    May 2007
    Quote Originally Posted by godspd1 View Post
    I have a 206 Stage 2+ Revo with CTS Turbo sports catted downpipe to resonator delete (they just cut out the suitcase)
    Sounds with windows up is pretty much normal, but with windows down it does sound more like a stock 7R or 7R with just exhaust tips. I assume mostly from the res delete. I’d say go with the intake mods first then go with downpipe when/if u get the stage 2 done. With revo they activate the exhaust overrun in S mode (not profile but physical sport mode) so above 3k rpm I get some pops but only turned on in tunnels.
    I’ll get a cat back later, it isn’t a priority atm.
    What I recall on the Passats is that they do in fact have a valve but it’s stuck open (even tried closing it on OBDEleven)
    The only time I have a rattle of some sort is during cold starts in reverse.
    I made a video with sound differences (sorry to self plug, also shot on iPhone)
    2018 Passat R-Line 206kw modified - REVO tuned - YouTube
    Just watched your video, do you get the option of a Heated Front Windscreen in New Zealand?
    It looks like you have one...
    Feb 2022
    Quote Originally Posted by ope126 View Post
    I didn’t buy it new (2nd nz owner) but shouldn’t heated front windscreens be in all cars? Do you mean vents to the windscreen for when it fogs up or all the time heated?
    I don’t believe it is heated but it works as normal with AC
