You can pull them out and soak the in petrol or diesel for abit then blow them out.
Hi,
Have B7 Alltrack, 2nd time I know that washer nozzle for passenger windscreen is totally blocked. I'm guessing the "Bars Bugs" is gelling and causing the blockage. Any tips on clearing the blockage as I'm a few months off service and don't want to book in early for something so innocuous.
Also recommendations on best washer additive to use?
Thanks.
WestOiler125
MY13 Passat Alltrack
125kW 2.0L TDi DSG
Volks Handy
Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
10 years experience working for Audi/VW/Skoda
Now in Perth NOR, Western Australia.
Bars Bug - do they still sell that stuff???
Here are a few threads that will answer your questions; Washer fluid questions and Windscreen Cleaner Fluid Additive
I hope this helps...
I use the vw additive
Yes mate, Bars Bugs still on the shelf at your local servo. Was recommended to me years ago and has caused no issues until recently.
I have a go at pulling it out and giving it a clean/blow out.
WestOiler125
125kW 2.0L TDi DSG
Hay mate, I have done the same mistake, mixed Bare Bugs with original liquid, it's now clogged, used thin guitar could to clear the blockade, but how did you managed to find a permanent solution.
Las
