Use a stitching needle/paper pin to clean the tip. Also it depends on the wiper fluid you are using, sometimes if its too concentrated it can gunk up if not used regularly and too much sun . A very good sign is that the passenger side it working meaning most of the other issues less likely. Mine had slightly lower spray pattern and I did the above, used quite a bit of spray fluid at once and eventually the gunk came out and its working fine now.
