Windscreen washer system losing fluid - help please
My windscreen washer system is losing fluid with a few drips sometimes visible under the car. The leak is very slow so I'm hoping it's something simple like a loose hose rather than a split bottle which I understand is located in the front bumper. Has anyone had this problem? Would appreciate advice on the best place to start looking. Thanks.
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
