Results 1 to 4 of 4
Thread: Wet Floor - Drivers Footwell
    Jan 2015
    Hi guys,
    After any hints how to stop water leaking into the drivers side foot well? I have cleared the drains under the windscreen runoff and removed leaves and mud from behind the plastic wheel arch covers.
    Thought I had it beat but the problem still persists! It only affects the drivers side (right) side of the car.. nothing in the rear foot wells.
    I have a 2011 Passat wagon.
    Thanks in advance,
    Jad
    Annangrove, NSW
    try to clean your sunroof drains.
    Jan 2015
    Unfortunately no sunroof!
    Mar 2015
    Might be coming from the aircon, check if there any damage in the evaporator well inside the cabin (behind the dash). I had this issue in a Lexus in the past. The water used to come up when ever it is humid and I run the aircon for a long while. Inspect the aircon parts behind the dash to the best you can. I know there is very little space in the Passat, so a snake inspection camera might help.
