Check for leaves and other dirt and debris blocking the drains under your plastic windscreen cowl. If that water cant drain away it could get into the cabin.
The floor mat and the carpet under the floor mat in the driver's footwell is quite wet and I'm looking for possible causes. The car has no sunroof, the windscreen has never been replaced and does not seem to be leaking, there is no loss of coolant that would suggest a leaking heater core and there is no evidence of water running down the plastic cover over the firewall.
Has anyone experienced this? Any ideas? Is there drain that is prone to blocking?
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
Lucas_R you were absolutely correct. I poured water into the edge of the plenum between the plastic cover and the bonnet hinge. Water ran from a retaining screw in the firewall into the footwell. Problem solved! Thanks.
