Sounds like what happens when your battery is well on the way out
I've recently had my rear view camera no longer working, the rear electric boot not opening properly, and today a lot of dahsboard lights coming on, eg. no abs speed sensors, no parking sensors etc. Am wondering if I can have bad / corroded wiring or a faulty gateway? I tried scanning with VAG-COM, but half the time it says "Unable to communicate". If I try again, half of the time it works. I got halfway through the auto-scan after trying a few times. I also managed to save each error manually by retrying.
Any ideas?
[shortened]
PHP Code:
VCDS Version 19.6.2.0 (x64)
Data version: 20190930 DS308.0
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53
56 61 62 6C 6D 72 77
VIN: WVWZZZ3CZDE0XXXXX Mileage: 220840km-137223miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
33-Flux Capacitor -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 06J 906 027 DE HW: 06J 907 309 B
Component: MED17.5.2 05 5359
Revision: PAH04--- Serial number: VWZCZ000000000
Coding: 0404000C24070160
Shop #: WSC 40139 959 131616
VCID: 71C70889681165C758-8025
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 -
Freeze Frame:
Fault Status: 01101111
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 220785 km
Time Indication: 0
Date: 2015.03.12
Time: 15:06:04
Freeze Frame:
RPM: 1538 /min
Load: 23.9 %
Speed: 70.0 km/h
Temperature: 97.0∞C
Temperature: 42.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 13.081 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 Q HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: CU501511237286
Coding: 0000020
Shop #: WSC 01049 002 1048576
VCID: 3FA39EB16EC5C3B79E-806B
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 9
Reset counter: 10
Mileage: 220785 km
Time Indication: 0
Date: 2015.03.12
Time: 15:06:04
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
Component: J104 C2 450M VDF5 0024
Revision: --H07--- Serial number: 00000005930578
Coding: 0001914
Shop #: WSC 05311 000 00000
VCID: 77D3369106753BF796-8023
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 5
Reset counter: 245
Mileage: 220785 km
Time Indication: 0
Date: 2015.03.12
Time: 15:06:04
Freeze Frame:
Speed: 68.0 km/h
Hex Value: 0x0001
Bin. Bits: 00000000 00000000
Voltage: 13.00 V
Bin. Bits: 00011111
Count: 18
Hex Value: 0x0000
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 9
Reset counter: 245
Mileage: 220785 km
Time Indication: 0
Date: 2015.03.12
Time: 15:06:14
Freeze Frame:
Speed: 68.0 km/h
Hex Value: 0x0000
Voltage: 13.00 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 F HW: 3AA 937 087 F
Component: BCM PQ47 M 421 0465
Revision: BA421001
Coding: 0008000000000000009802805400006403510088426D8D60648046200041
VCID: 3D5FE4B9A4C9D1A78C-8069
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 21061 26 0612
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 260612 05 54 0403
Coding: 0230ED
1 Fault Found:
02739 - Bulb for Tail/Brake Light; Right
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 10
Mileage: 220530 km
Time Indication: 0
Date: 2015.03.03
Time: 00:40:55
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261216601722
Coding: 349106
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 44A9915DCF23A06FC3-8011
1 Fault Found:
13637396 - Databus
U1123 00 [009] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 245
Mileage: 220785 km
Date: 2020.10.19
Time: 15:06:03
Coding: 0000020
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 10
Mileage: 220785 km
Time Indication: 0
Date: 2015.03.12
Time: 15:06:04
Coding: 0001914
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 245
Mileage: 220785 km
Time Indication: 0
Date: 2015.03.12
Time: 15:06:04
Freeze Frame:
Speed: 68.0 km/h
Hex Value: 0x0001
Voltage: 13.00 V
Bin. Bits: 00011111
Count: 18
Hex Value: 0x0000
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
132TSI Tiguan Allspace
Hmm, didn't think about that. I'll put a charger on it overnight to see if it improves things.
The rear view camera can drop out if the cabling is bad though?
This is absolutely the battery. I have just been through this on my daughter's A1
Chassis Type: 8X-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8X7HB021217 Mileage: 59870km-37201miles
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Sad to say, but a charge will not fix this, it may help in the very very short term, but its likely a replacement will be required. ... Unless it somehow is not getting properly changed when driving. Incidentally, that was actually the main cause for the A1. A mostly dead battery (30% life left) and an issue with module 08 HVAC caused a drain on the battery at all times. The charging could simply not keep up with the continuous drain. Ended up with a new battery and a new HVAC module![]()
I did a charge overnight, and I managed to clear most errors. Still has some communication errors, so I agree I probably need a new battery. The rear view camera still has no communication though, so I believe it's either a gateway or cabling issue. The charger showed 13v this morning, but I believe a good battery should show more than that when charged?
