Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Urgent help!!! R36 won't unlock
  1. #21
    Pacific Paradise QLD
    I use unsolder braid and a 25 watt fine tip iron and no more heat than necessary. If you can get a fine tweezer just under it might be enough weight to lift the pins when heated without the braid. Dont leave iron on for too long as it will lift the pads off the board.
    Easier to do it than explain it
  2. #22
    Jun 2015
    Willy, Victoria
    Hey guys. So I just replaced the battery in my remote this evening and all the buttons now work perfectly. No need to solder anything. Thought I'd try the easiest/ "most obvious" solution 1st and I'm glad I did...
  3. #23
    Nov 2010
    Well well. Might have to try myself. So was there any issues with the remote not working after changing the battery? Reason I ask is that I have heard that some people have had issues after changing batteries which I found a little weird. Any idea what battery it is off hand so that I can purchase one on the way home tonight?
  4. #24
    Jan 2015
    QLD
    Mine died on Monday this week while I was out (had to use the key to open the car).
    The battery is a CR2032
  5. #25
    Jun 2015
    Willy, Victoria
    Quote Originally Posted by snerlo View Post
    Nope it worked perfectly. Which I'm happy about because not having a working spare made me nervous.
  6. #26
    Nov 2010
    Cheers guys. Will give that a go first.
  7. #27
    Nov 2010
    Well, I'm with domatron. New battery and away she went. Unbelievable! Anyhow, thanks for the tips guys.
  8. #28
    Dec 2014
    Hey I know this is a super old thread, just wanted to thank everyone for the useful tips.
    Had the exact same problem with my R36 today (lock button working, unlock button not).
    Knew about the key hidden in the fob, but could not find the key hole anywhere.
    Bit of a worry that VW owners on the internet are more helpful than the VW service dept. at my local dealer.
    Not only did he not mention the key or key hole when I told him I had to climb in through the tailgate, but he also specifically said that the battery would NOT be the issue as I would get a low key battery warning msg on the dash. Suggested I book it in for diagnostics and most likely fix was a $700 actuator. Will try a $5 battery first after reading this thread.
    Thanks again.
