Kamold is going to retrofit MED17.6.2 in his Passat for using 7N0 radar.
Maybe your MED17.5 has a similar limitation too?
I PMed you![]()
It's MED17.1.6.
Fully working. F2S works as it did previously with 3AA radar.
Deleted a lot of the autoscan so it fits in the character limit:
Code:Address 01: Engine (0-32-BWS ) Labels:. 03H-907-309-V1.clb Part No SW: 03H 906 023 L HW: 03H 907 309 A Component: Passat R36 DQ H04 2758 Revision: MFH04--- Serial number: 00000000000000 CVN: CA0B08DD Coding: 00250032246700000000 Shop #: WSC 00046 123 12345 ASAM Dataset: EV_ECM36FSI01103H906023L 002011 ROD: EV_ECM36FSI_002.rod VCID: 2B03F967438B5373261-807E VINID: 9E69EAAAA0D3A8954020314320D2950B7E No fault code found. Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb Part No SW: 0BH 300 012 D HW: 0BH 927 711 C Component: DSG DQ500-7A H08 2224 Revision: 00H08V01 CVN: 45F15B25 Coding: 0014 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMDQ500021 001001 ROD: EV_TCMDQ500021_VW36.rod VCID: 2411125B2E559C0BE7B-8070 No fault code found. Address 03: ABS Brakes Labels: 3AA-614-109.clb Part No SW: 3AA 698 109 N HW: 3AA 614 109 AL Component: J104 C2 450M VEA9 0042 Revision: --H07--- Serial number: 00000007379684 Coding: 0119716 Shop #: WSC 12345 111 45799 VCID: 44D1B2DBC295BC0BC7B-8010 No fault code found. Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb Part No SW: 3AA 937 087 N HW: 3AA 937 087 N Component: BCM PQ47 M 422 0475 Revision: BA422001 Coding: 0608000068000000048800885100083463F5008863218D60648840200040 Shop #: WSC 12345 123 61029 VCID: 45D7AFDFC5AF8503D05-8010 Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB Component: Wischer 10090 22 0601 Coding: 00B7B5 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 121108 05 54 0402 Coding: 033028 No fault code found. Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb Part No SW: 7N0 907 572 C HW: 7N0 907 572 Component: ACC Bosch PQx H03 0211 Serial number: 28121604384333 Coding: 003C1100FE073B Shop #: WSC 12345 123 61029 ASAM Dataset: EV_ACCBEGVW361 001006 ROD: EV_ACCBEGVW361.rod VCID: 3635D81388C91E9B49F-8062 No fault code found. Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb Part No SW: 3C5 953 501 BM HW: 5K0 953 569 T Component: LENKS.MODUL 016 0180 Revision: FF010041 Serial number: 20160725000799 Coding: 399AA5000B Shop #: WSC 12345 123 61029 ASAM Dataset: EV_VW360SteerWheelUDS A03004 ROD: EV_VW360SteerWheelUDS.rod VCID: 71BF2B0FA12779A35CD-8024 Multifunction steering wheel control module: Subsystem 1 - Part No SW: 1EA 959 442 A HW: 5K0 959 542 A Component: E221_TinyQ_VW H09 0013 Serial number: 00000000000000VW0001 Coding: 820000 No fault code found. Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1 Part No SW: 3C8 920 881 HW: 3C8 920 881 Component: KOMBI H04 1104 Serial number: 00000000000000 Coding: 751F230000 Shop #: WSC 00127 935 15958 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733 ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod VCID: 6A8D3C638CF18A7B1D7-803E No fault code found. Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb Part No SW: 7N0 907 530 BR HW: 7N0 907 530 AJ Component: J533 Gateway H51 1708 Revision: H51 Serial number: 140113F2000916 Coding: 462007 Shop #: WSC 12345 123 61029 VCID: 015F7BCF91076923ACD-8054 No fault code found. Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 0BS 907 554 A HW: 0BS 907 554 A Component: Haldex 4Motion 4013 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 44D1B2DBC295BC0BC7B-8010 No fault code found. Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 243 3501 Revision: 00H15000 Shop #: WSC 00046 000 00000 VCID: 392FD32FB557F1E3A4D-806C No fault code found. Address 46: Central Conv. Labels:. 3C0-959-433-46.clb Part No SW: 3AA 959 433 F HW: 3AA 959 433 E Component: KSG PQ47 ELV 052 0714 Revision: 00052000 Serial number: VWZCZ000000000 Coding: 00910A0051030EF630031C1DF008DFCE507801 Shop #: WSC 12345 111 45725 VCID: 3C21CA3BBA65C4CBBFB-8068 Subsystem 1 - Part No: 1K0 951 605 D Component: LIN BACKUP HORN H08 9001 Subsystem 2 - Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Subsystem 3 - Part No: 3C0 951 171 C Component: Innenraumueberw.004 0611 No fault code found. Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ Component: EZE_2 H51 1708 Revision: H51 Serial number: 140113F2000916 Coding: 00000001 Shop #: WSC 12345 123 61029 VCID: 6FBB2D77B7936F534A9-803A No fault code found. Address 53: Parking Brake Labels: 3AA-907-801.clb Part No SW: 3AA 907 801 J HW: 3AA 907 801 J Component: J540 EPB4 VW-63206 0012 Revision: H19 Serial number: 00000000248887 Coding: 0022157 Shop #: WSC 12345 111 45725 VCID: 3829D62B8E5DE8EB5B3-806C No fault code found. Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0136 Revision: 00H04000 Serial number: Coding: 2311185 Shop #: WSC 00046 000 00000 VCID: 3431E21B92350C8B77B-8060 Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0004 Coding: 00000035 Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0004 Coding: 00000035 No fault code found. Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb Part No SW: 5C0 035 680 G HW: 5C0 035 680 E Component: MU-S-ND-ER H31 0478 Serial number: VWZAZ2T5074914 Coding: 020408010000000091111105400908001F01078600F081014E Shop #: WSC 12345 123 61029 ASAM Dataset: EV_MUStd4CTSAT 001022 ROD: EV_MUStd4CTSAT_VW32.rod VCID: 25170F5F256F6503F05-8070 Data carrier: Subsystem 1 - Part No SW: 5NA 919 866 BN HW: Component: MRM3 2022 --- 1710 Serial number: - No fault code found. Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 3AA 907 273 F HW: 5Q0 907 273 Component: RDKBERU30 H04 0011 Serial number: 40000000055443 ASAM Dataset: EV_RDKBERU30 005005 ROD: EV_RDKBERU30_005.rod VCID: 372BD5178FC3E793529-8062 No fault code found. Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb Part No SW: 3Q0 980 654 S HW: 3Q0 980 654 A Component: MQB_B_MFK H04 0920 Serial number: 290515null1593 Coding: 000408020000040100021044C096880092000E10002080 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_MFKBoschMQBB 002041 ROD: EV_MFKBoschMQBB_002.rod VCID: 47CBA5D7FF239713229-8012 No fault code found. End(Elapsed Time: 02:11, VBatt start/end: 12.0V/12.0V. VIgn 11.7V, udsna)--
How did you enable ACC on this ECU?
As I know, we need to flash this Golf 6 ECU to Passat B6 ECU by firmware 03C 906 016 P for EPB and ACC compatibility. Simply with ODIS-E with VWfleet project, for example.
What about component protection for your J428 7N0 907 572 C with old J285 dashboard w/o CP compatibility?
ACC enable by coding II using code 13377. Deactivate cruise before using 16167. Might need security access 12233, but I think not. Even tho it doesnt support EPB, this ECU works perfectly fine with EPB+Autohold and 3AA front radar.
When installing 7N0 front radar, ACC doesnt work anymore. Currently trying to find out why. You suggest using Passat B6 ecu (03C 906 016 P). Why not Passat B7 (03C 906 016 DH)?
Regarding component protection: PM me, I know a guy who makes it work.
Because our golf EBUs 03C 906 016 AJ based on HW: 03C 907 309 A. Same as B6' 03C 906 016 P. All of them have short coding and ACC simply activating by 13377 (11463 for deactivating ACC support).
B7 EBUs (03C906016DH or 03C906016GC) based on other hardware 03c 907 309 e with long coding and not support ACC from factory (VAG injure CAXA 1.4 Passats). But drsedoy can add ACC support for them.
Now I'am trying to find a simplest way to upgrade my EBU to modern version from B7 or Yeti. But it is a background task and not help us with 7n0 distronic ( j428 ).
My guess (!) is: There's a difference in the CAN messages between ACC and ACC+FTS. Our Golfs never came with ACC, but afaik it can still be activated in most engine ECUs. But not ACC+FTS. Since Passat B7 came with EPB, my guess (!) is that the engine ecu will only work with ACC+FTS if it is prepared for EPB. That's why I'll try to install said Passat B7 engine ECU in the next weeks. I'll report back.
Pascal, did you fix basic ACC on 7n radar?
FtS worked with 3aa radar?
p.s. I got Passat B7 engine ECU MED 17.5.5 for experiments
No. Will report back after the ecu arrived, its still in transit.
I learned about FtS only after installing 7N0, thats why I never tried to enable it. So i cant say. As i still have the old radar here, i can test it.
About your kind offer: thanks! Can you provide more info about said MED17.5.5?
