Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: TPMS reset not working
    Jul 2016
    Launceston, TAS
    Unless you look inside the tyre you can't tell the difference.
    The sensor is behind the stem. (Stem is part of it but looks no different externally to a regular valve stem)
    Ah OK. I thought it had a nutted stem on it. Like this:
    TPMS reset not working-tpms_valve_stem-jpg
    Mine just look and flex like standard rubber valve stems
    Yeah fair point you can see a difference with a regular stem.
    If op issue isnt due to a bad sensor with tpms direct they will need to get a scan done as the abs should have logged a fault.
    Jul 2016
    Launceston, TAS
    Righto
    I'll take it back to the shop. They left a thermometer in the aircon vent anyway so I should return it.
    Ta
