Originally Posted by
00100100
That's correct, the B7 in Aus uses the ABS sensor. Therefore it can not tell the pressure, but it can tell the tyre is deflating due to a smaller circumference. I confirmed this few weeks ago when I logged into vag com.
Using the ABS sensor, although it can not tell the pressure, however it is more reliable as previous modules that used pressure sensors caused few issues apparently. e.g. the person replacing the tyres needs to be careful not to break the pressure transmitter.
I think in AUS, the Passat CC can tell the pressure. Also, in the US, it is a requirement for all new cars to be able to display the tyre pressure. Hence they use the other system there.
