Results 1 to 6 of 6
Thread: Towbar coding / connection (and a haldex error)
    Mar 2009
    UMG Brisbane
    2013 b7 v6 wagon
    I have installed the towbar itself, as well as the westfalia oem module
    Passat B6 Towbar & Passat B7 Towbar - LED Towbar Wiring Kit - Australia Tow Bars & Performance store
    I didn't use the loom that came with the module to the back of the car, as my car had trailer prep.
    Unfortunately, when I plug it in I get a very dim brake light, and no indicator or tail lights. I'm led to believe that this is due to the trailer module not having power. Fished around under the dash, the connections seem to be in place but there is one plug that doesn't seem to have a home, and I can't find it's mate. No fuses blown that I know of (although I haven't checked since I did the coding)
    I've plugged in the obd11, and activated towing control 69, but that has caused more errors. I've now got a persistent "globe" warning on the dash, not sure if it is the trailer module or the led #plate globes.
    Any pointers here? Would like to get the trailer lights working if possible, although they're just for a bike rack.
    Also found, completely randomly, a haldex clutch pump failed error. Is this something I should be worried about?
    Sent from my SM-T835 using Tapatalk
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Mornington Peninsula, VIC
    Did you splice the two can wires under the dash to connect the can signal to the back harness?
    Also, Haldex pump failures are common, the filter gets clogged, and the pump runs all the time, burning the brushes out.
    Clear the error, and if it returns or you don't have AWD (You will know pretty quickly in the v6 if you don't) you will need a new pump and filter for a rebuild.
    vagparts.com.au/products/0ay598549a-haldex-pre-charging-pump-mk6-8p-2
    Gen 4 Haldex Service Kit - Genuine - Volkswagen MK5/6 & Audi 8P/8J — VAGPARTS Australia
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Mar 2009
    UMG Brisbane
    Thanks @MIG.
    Is that the wires under the dash that I've pictured? Either way, no...
    I suspect you're right about the haldex, I do occasionally get a traction light when I don't expect to...
    I will take a picture tomorrow, but there is a splice under the driver's dash area near the BCM, which connects the can network to the trailer module, has yellow wires with foam protection from memory; I think that was the way the dealers would fit the trailer module at the time.
    This is near the driver's door rest on the right side, three way splice. I have a dealer fitted tow bar.
    Sent from my SM-N960F using Tapatalk
    Mar 2009
    UMG Brisbane
    Cheers,
    I see what that is now. In my pic you can see the blue connector which is floating and the two black ones which are connected
