I did the timing chains at the beginning of the year at 177,000km. My chains had the start up rattle for years and Alfredo from Muller & Muller kept on saying they needed to be replaced from at least a couple of years. I did check the cam phasing parameters on OBDEleven and they were right on 5 degrees, so I thought it best to do this,
I go most of the parts from FCP Euro in the States - their timing chain kit, main oil seal and rocker cover gasket - that came to $780, I didn't get the brake pump gasket or inlet manifold gaskets - so I paid through the nose for those parts here - $290. Alfredo's labour was $2,000 - so it was about $3,100 all up, which I thought was fair.
However Alfredo told me the rocker cover was warped and would leak oil into the head. Sure enough, I soon had a misfire, which meant I needed to order a new rocker cover, this time from Pelican Parts - not OEM but still German - for about $200 (over $600 here). I also needed a new coil and spark plug as they were wrecked by the oil. At local prices this was expensive - the total bill was about $800, which included labour. I saved the old PCV as it is only a matter of time before PCV in the new rocker cover fails... I will also get a spare set of coils from the States soon.
Biscay Blue MY10.5 Passat R36 Wagon
Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
Atlantic Blue MY19.5 Golf GTI
Options: Luxury Package and Sound & Style Package.
