Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Swapped B6 climatronic module to B6/B7 - WTF
  1. #21
    Oct 2017
    VIC
    Quote Originally Posted by MIG View Post
    Try this coding 0600002002; this sets the vehicle type to B7 instead of CAN dependant and the climate to "more air"
    Tried this code yesterday - unfortunately no luck with 'coding rejected - error 31: request out of range'. What's puzzling I have another Climatronic module (which I think is also from B7 but no seat warmers) and the effects of fitting it are the same.
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
  2. #22
    Mornington Peninsula, VIC
    hmmm my coding must be different; I do have the newer style unit with the little LCD screens.
    I will grab my old unit out of my spare parts box tonight and play a bit with coding options.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  3. #23
    Oct 2017
    VIC
  4. #24
    Oct 2017
    VIC
    As I'm not really getting any meaningful cold air coming through the cabin I thought I'll just swap back to the B6 module and see how it behaves.
    After clearing the fault codes the (13701456 - Function Restricted due to Missing Message(s) U1111 00 [009] [New feature! Extended UDS fault detail is only supported by current gen. interfaces]) has now gone BUT ... I'm now getting Air Quality Sensor - G238 fault code.
    I'm curious whether (if the sensor is really faulty) this would perhaps interfere somehow with the operation of the climatronic module regardless whether B6 or B7? (I've ordered a new sensor just in case)
  5. #25
    The sensor switches automagically between outside and recirc based on the amount of toxic fallout being ingested into the system.
    So not sure it will affect the lack of air in the cabin.
    The fact the missing message is gone is just because the B6 climatronics doesn't expect an additional CAN message from the BCM as opposed to the older Bordnetz CECM
  6. #26
    Oct 2017
    VIC
    I guess what I was really hoping for is when I fitted the 'old Climatronic' back things would return to normal. Since that has not happened it puzzles me even more.
  7. #27
    Oct 2017
    VIC
    Well, having tried 3 different climatronic units - 2 x B7 (1 with and 1 without the seat warmer switch), 1 x B6 (which I acquired in the week) I was dumbfounded that ALL would cause the same HVAC fault. Even the newer B6 seemingly identical to mine once fitted resulted in the HVAC fault.
    Swapped B6 climatronic module to B6/B7 - WTF-20231001_192344r-jpg
    Original B6 climatronic fitted, recent B6 underneath, B7 without seat warmer switch (B7 with seat warmer switch is missing from this picture.
    So, in desperation I fitted the original (half broken) unit and you guess it ... the fault has magically gone.
    Swapped B6 climatronic module to B6/B7 - WTF-20231001_193521r-jpg
    I tested the 'old' module and it definitely works as before - down to 3C.
    Swapped B6 climatronic module to B6/B7 - WTF-20231001_192615r-jpg
    The old B6 module (connected) and recently acquired B6 climatronic underneath.
    What gives?
    As to the other matter of Air Quality Sensor G238 fault code - I received a replacement sensor the other day but when I had a look around the w/wiper motor I just couldn't find one. Suffice to say that with 'old' climatronic fitted the Air Quality Sensor fault code has cleared as well.
