Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Swapped B6 climatronic module to B6/B7 - WTF
    Oct 2017
    VIC
    Greetings,
    Swapped B6 climatronic to B6/B7 as the temp dial was playing up. Physically an easy job however I'm slightly confused about the newer B7 unit settings. In the B6 when the yellow ECON light was ON the A/c was OFF. When the the ECON light was OFF the A/c was actualy ON. With A/c ON I was getting good temp. out readings - say around 4-6C.
    Swapped B6 climatronic module to B6/B7 - WTF-20230520_151033s-jpg
    my old B6 climatronic
    B7 unit - with the light OFF it says the A/c is OFF (opposite to B6). With the yellow A/c light ON the unit is showing ON - again opposite to the B6. Perhaps I'm confusing here this yellow light with the B6 yellow ECON light.
    So, Ok I could understand the B7 uses different approach here but how do you explain that now whether with A/c ON or OFF the best cooling I get is 10-12C? So, with the temp selection set to minimum (low) even now in winter I can not get much in the way of cold air coming out. I should add that I did read few of the climatronic related posts and upon fitment I did run HVAC reset & calibrate program.
    Swapped B6 climatronic module to B6/B7 - WTF-20230605_103752s-jpg Swapped B6 climatronic module to B6/B7 - WTF-20230605_103726s-jpg
    B6/B7 unit
    The other thing I noticed is that with one of the A/c settings (ON or OFF I can't remember which one now) there does not seem to be any air coming out of the centre consol face air outlets. Any ideas?
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    Mornington Peninsula, VIC
    The lighting logic for the new console is correct; B7 light on = AC on.
    Did you update the coding at all? I think most of the B7s used variable output compressors without a clutch, and the older generation used the traditional mag clutch arrangement.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Oct 2017
    VIC
    Quote Originally Posted by MIG View Post
    No, have not coded anything. I have not had to connect the VCDS in a long while so can you point me where I should be looking and what coding I need to change? BTW I have not changed the a/c compressor unit itself only the climatronic control.
    Just do an auto scan of the car and see if you get any results under the 08-AutoHVAC
    There is a compressor run-in procedure that needs doing, too, if the module is replaced.
    Check out this guide here VW Golf (5K) Climatic - Ross-Tech Wiki
    Jan 2015
    Melb
    The b6 has the variable compressor too. No clutch.
    Oct 2017
    VIC
    I'll check it out - thanks.
    Oct 2017
    VIC
    I've done the flap adaptation & compressor run in. It completed successfully. During the calibration steps I could see the (low) temperature going down to about 4C. Strangely, now when I turn the dial to LOW the cold output seem to be only about 8-10C but if I select 18C it goes down to about 4C. Maybe the climatronic module I have is jinxed
    Albany, WA
    Quote Originally Posted by Old Navman View Post
    From memory it had something to do with high speed fan and temp that is low but not maximum low.
    4 C might be the lowest but car cannot achieve it with a high fan speed.
    I could be wrong though, good job switching.
    Oct 2017
    VIC
    Quote Originally Posted by sn809 View Post
    I know what you're saying - the lowest temp possible should be with selector set to LOW and fan @minimum speed. Those above temps were, of course, measured while driving.
    Oct 2017
    VIC
    I'm still not getting the correct airflow from the B7 Climatronic unit despite many attempts to re-set it. So I'm wondering whether the following errors could explain why it's not doing what it suppose to.
    Not sure if this is correct but I've read somewhere that when you upgrade from B6 to B7 Climatronic you might either have to change the existing coding or in fact add a brand new coding (a bit or a byte so that the system recognizes the new Climatronic unit. Has anybody come across this sort of problem?
    The following faults are from the scan log I've uploaded in my other (fuel gauge problem) post.
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000001002
    Shop #: WSC 01324 020 00200
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_ClimaAutoBasis_VW46.rod
    VCID: 6ED37BBFB1970CF4E1-803A
    1 Fault Found:
    13701456 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 104
    Mileage: 350514 km
    Date: 2023.07.31
    Time: 11:08:28
    Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3640P151190AC5
    Coding: FD82FF4F00020200F103
    Shop #: WSC 12345 123 12345
    VCID: 2F6DA6BBBE1D45FCAA-807A
    2 Faults Found:
    01320 - Control Module for Climatronic (J255)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
    disreagrd this fault
    01517 - Control Module for Trailer/Towing Sensor (J345)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 144
    Mileage: 347974 km
    Time Indication: 0
