Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Spare tyre on Alltrack ?
    its a full size alloy unless you get the sports kit and then its a steel rim what a rip
    Jul 2014
    Queensland
    Nup.. It is steel rim even without the sports kit..
    Jun 2011
    So is it just the difference in rolling diameter that makes it limited to 80km/h?
    Was cleaning my Alltrack today and popped the spare out to have a look.
    As I'm researching A set of steel rims for off-road & winter use I wanted to see what the standard spare rim is.
    Tyre is Pirelli Cinturato P7
    215/55/16 97w
    Nice tread
    There a little bit of clearance around it, maybe 10- 20mm. You could always cut away some of the polystyrene under the jack kit to give a bit more clearance.
    Pacific Paradise QLD
    According to the tire comparator here the space saver has a 16mm smaller diameter so the thing to do would be jack the car up and take a wheel off and see if it fits in the hole. Logical thought. If it fits maybe go to the wreckers and see if you can buy a matching wheel
    Wheel-Tire size comparer - RIMSnTIRES.com
