Nup.. It is steel rim even without the sports kit..
its a full size alloy unless you get the sports kit and then its a steel rim what a rip
So is it just the difference in rolling diameter that makes it limited to 80km/h?
Was cleaning my Alltrack today and popped the spare out to have a look.
As I'm researching A set of steel rims for off-road & winter use I wanted to see what the standard spare rim is.
Tyre is Pirelli Cinturato P7
215/55/16 97w
Nice tread
There a little bit of clearance around it, maybe 10- 20mm. You could always cut away some of the polystyrene under the jack kit to give a bit more clearance.
According to the tire comparator here the space saver has a 16mm smaller diameter so the thing to do would be jack the car up and take a wheel off and see if it fits in the hole. Logical thought. If it fits maybe go to the wreckers and see if you can buy a matching wheel
Wheel-Tire size comparer - RIMSnTIRES.com
