Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 115
Thread: Snerlo's R36 DRL Mk2 Installation
  1. #31
    Nov 2010
    Yeah me too. It is a bummer that they don't have paypal but there is some other options that are similar to paypal but I am not sure whether I need to sign up to another one!
  2. #32
    Sep 2011
    Epping, Victoria
    Ordered these and can't wait to have them fitted. Wondering whether anyone who had already installed them can share and take few pics of the location within the engine bay where they have thread through the power lead to get to the fuse box on the driver side - simply can't find a spot for it. I know snerlo you mentioned earlier in an earlier post to thread through a hole where the clutch is but yea can't find it.
    Also what the process of tapping the lead to the parker light for the dimmer of the DRL? Sorry to sound like a newb but yea near to the scene of modding cars Any help would be much appreciated.
  3. #33
    There is a cutout in the carpet in the firewall above the 'clutch pedal'. Under that is a rubber cover which you can carefully pop out towards you, then you're through to the engine bay.
    As for tapping the cable, best way is to use a suitcase connector like this: Red Quick Splice Connector 22-18AWG Pk6 - Jaycar Electronics
  4. #34
    Sep 2011
    Epping, Victoria
    Cheers, I'll check it out! And thanks for the cable tabbing suggestion.
  5. #35
    Nov 2014
    New Zealand
    Ok, so the DRL's arrived a few days ago. Thanks for the link.
    Included in the package was what appears to be an on / off switch. I'm guessing it's there so you can turn off the DRL's if you wanted to, and that you would leave it on all the time.
    Picture attached. Can someone confirm what it is for and where it is installed and mounted?
    Thanks in advance.
    Attached Thumbnails Attached Thumbnails Snerlo's R36 DRL Mk2 Installation-image-jpg
    2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
    2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
  6. #36
    I didn't bother with the switch. I always want them on. Up to you if you want to be able to switch them.
  7. #37
    Nov 2010
    Yeah, it's just an inline switch in case you want to turn them completely off for some reason. I didn't bother installing mine either
  8. #38
    Nov 2014
    New Zealand
    DRL's now installed and working as expected. Great and easy modification.
  9. #39
    Best. Upgrade. Ever.
    Well except for forced induction ECU upgrades.
  10. #40
    Jan 2015
    Hi guys
    Looking to purchase these from aliexpress and install as well
    From what I have read
    - remove grill to easily run the wires
    - no wiring to turn signals since these appear to be complete swap out units. Do you just unplug the old blinker unit and plug the new one in?
    - only wiring is to a power source and to the parker signal (but better to tap this into the main headlight signal?)
    May have got it all wrong so looking for some confirmation
    Thanks guys
