Page 12 of 12 FirstFirst ... 2101112
Results 111 to 115 of 115
Thread: Snerlo's R36 DRL Mk2 Installation
  1. #111
    Jul 2014
    Well I was wrong... These new DRL lights do require a 12v power source. Fuse location #33 in the engine bay fuse box is an ignition fuse so I tapped that. They don't dim which is disappointing so I may install a control box for that. We'll see if I can be bothered
  2. #112
    Apr 2017
    A quick question if I may about these blinkers, the originals that is. It seems there is only half of the fitting used at all and this is only for the blinkers? Is there supposed to be something else in the factory bumper mounted blinkers or is this space just for other models? Half the lens is clear so I assume there is something else supposed to be in there? This pic below shows what I mean well. Any ideas??
  3. #113
    There's meant to be LEDs in there, just like the inner tails where there is a mount for them just the holes haven't been drilled out
  4. #114
    Nov 2012
    Dulwich Hill
    Wheres the best spot to connect the ground wire - any suggestions? I have a red, black and blue wire. I suspect blue goes to the parkers for dimming.
  5. #115
    There are ground points in the engine bay, just have a look behind the headlights a bit lower down.
    Yes the dimmer wire needs to tap the parkers.
