A 60K service on this one is:
Engine oil & fitler
DSG oil & filter
Spark plugs
Haldex oil
You should also consider doing the cabin filter and brake fluid if they haven't been done in the last 2 years.
Hi All,
It has been a while since I posted - I guess that means everything has been going well!
At the end of 2013, I bought a 2008 VW Passat 3.2 Estate with 40,000km on it, and a dealer history.
I then had it serviced at 50,000km by an indy garage which specialised in European cars, but not the VW marque specifically. He basically gave it an oil/filter change. It has now hit 60,000km, and is 8 years old.
Can anyone advise whether I need to consider any major service items for this next service, or can it have another light service?
Excuse my ignorance - I know Alfa V6s back to front from a servicing perspective (mainly out of necessity - broken cambelts cause expensive damage), but I haven't delved into what to look out for in an 8yo VW V6.
Thanks in advance
Engine oil & fitler
DSG oil & filter
Spark plugs
Haldex oil
Thanks for the advice!
I will request all of those things.
Since my car has done low miles for the year, do you think there are any time-based service items I should consider?
Or does the last two items mentioned cover the time-based requirements?
Thanks
VW says everything is time/distance-based, depending on which comes first.
The 60K service is recommended every 4 years.
I would suggest doing it as per above, with the brake fluid and cabin filter, and using that as your new baseline as everything besides the air filter (every 45K/3 years), will be up to date.
Brilliant, thanks again!
not sure if you have DSG or not but, they need servicing every 60,000 also.
Current - 2015 Tiguan 155 R-Line.
Previous - Jetta MkV 147 Turbo, Viezu Raceday mapped, Carbonio CAI, Quad Exhaust System, R8 Coil pack, Whiteline Swaybar, GTi Steering wheel with paddles, Alloy pedals, RNS510 & Leather.
its going to need the full major service just like i have to do next week, its a costly one aswell.
2008 VW R36 Sedan, Candy White
2013 VW Polo Gti, candy white
1964 Holden EJ Premier, Formula Blue
60,000 km is a major service. It's probably the biggest. Like Umai Naa says, you need to do DSG oil & filter + Haldex oil + spark plugs. It will be expensive but you'll have a lot of fun driving ahead of you before you hit 120,000 km and have to do it all over again!
I agree it would be very sensible to do brake fluid and cabin filter as well to establish a new baseline. If you want to save money, the cabin filter is a breeze to do yourself. If you're a meticulous sort of person, you'll take a lot more care to vacuum & wipe out all the debris before installing the new filter than a workshop might.
Interesting that my reading shows air filter change is recommended every 60,000 km. That struck me as a long interval for something so critical, so I like the recommendation of 45,000 km/3 years. Of course that interval is highly dependent on whether your driving is city or dusty country. Dusty country driving would need more frequent replacement. Interestingly, I have a VW of America document showing the recommended interval for a 3.2L V6 is 60,000 miles / 96,000 km / 6 years!
2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
Interested to hear how it goes jimmy jonkers and also where are you getting done?
its getting done at prestige and performance on thursday. i will let you know snerlo
