Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: SD card Error reading
    Pacific Paradise QLD
    Quote Originally Posted by chriswhv6 View Post
    So your saying if i set it to random play it might solve the long load up issue?
    I have noticed every time i select to play from the Media Card it always plays the exact same song from the exact same folder.
    Honestly i have mucked around in the settings at all...just was happy that the card finally started to play LOL.
    Cheers thx for the confirmation on larger card sizes working under the Fat32 file format.
    Yeah i didn't realise that the 128Gb pro one i bought was formatted under Exfat when i was trying to test it out the first time.
    I managed to fit like 90% of my fav music folders on the 32Gb card i bought so i guess its alright for now.
    If i could just solve the 5 min+ loading time each time i switch the stereo on that would be brilliant!!
    If you put all the TRACKS ONLY on the card and tell it to play random you will get all your music to play and it only takes moments for mine to be there
    In fact I loaded all mine onto the SSD memory and its always there and plays instantly. Just make sure each track regardless of artist has a unique name even if you have to rename it with a number on the end
    I have 1089 tracks and they only take up just over 5gb and is on a micro SD card in an adapter as thats all I had spare so I chucked it in and loaded them onto the HDD and it all worked in my B7 Passat.
    Can add more onto it and tell it to load them and it will and not add tracks that are already there.
    EDIT FOR CLARITY
    Oct 2018
    Im pretty sure i filled the card close to 25GB so if was to put the songs only on and have no folder structure it would be way to difficult then to find specific songs if i felt like it at any given time.
    If I remember correctly if you select 'List' it will allow you to scroll through every track.. I just play what comes up as background music and rarely bother selecting anything
