Hi,
Yeah, there is a Blaupunkt 5K0035456 with HW H06 and SW 0340.
I don't have a VCDS or VAG-COM. The Carista app is just for small tweaks to the car, it just happens to have the EPB service tool functionality which works over a ODB-2 Bluetooth ELM327 adapter.
I guess I need to find someone in Brisbane with VCDS and some knowhow to help fix the coding.
The coding looks quite straight forward, as you said Bytes 01 and 02.
From VW Radio Navigation System (RNS510) - Ross-Tech Wiki
RNS-510 coding:-
Byte 01 set value 01 (Volkswagen Sound System)
Byte 02 set value 04 (4 Speaker Channels (Front and Rear))
Should be it I guess.
Reason: Formatting
.:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
