Checking the menu :
GPS Antenna status disconnected
0 satellites visible
0 satellites tracking
Sent from my SM-G935F using Tapatalk
Just replaced my RNS510 1T0 035 680 Q, second hand one and the satilite position is incorrect.
Thinks im in a different city.
The arrow moves when driving.
Done a factory reset from menu and a soft reset (teo arrows and star button) and still same issue.
Before returning it has anyone had same issue and resolved it?
I dont have a cable to do a scan on it.
Any help would be appreciated.
Checking the menu :
Where is the aerial positioned and is it plugged in to the unit. You usually need to go for a drive for 30 mins or so to let the unit work out where it really is. But by your second post you seem to have a wiring fault maybe
Pluged in to original gps antena and i drove today for over hour.
I do have another antena that i did plug in gor a bit but had same issue.
Might have to check connections again and try the other antenna
Just a faulty connection all working now.
Anyone in western suburbs with vcds cable.
Need a quick coding as my fade is not available?
