Results 1 to 5 of 5
Thread: RNS510 Sat nav position
    Jan 2011
    Just replaced my RNS510 1T0 035 680 Q, second hand one and the satilite position is incorrect.
    Thinks im in a different city.
    The arrow moves when driving.
    Done a factory reset from menu and a soft reset (teo arrows and star button) and still same issue.
    Before returning it has anyone had same issue and resolved it?
    I dont have a cable to do a scan on it.
    Any help would be appreciated.
    Sent from my SM-G935F using Tapatalk
    Jan 2011
    Checking the menu :
    GPS Antenna status disconnected
    0 satellites visible
    0 satellites tracking
    Pacific Paradise QLD
    Where is the aerial positioned and is it plugged in to the unit. You usually need to go for a drive for 30 mins or so to let the unit work out where it really is. But by your second post you seem to have a wiring fault maybe
    Jan 2011
    Pluged in to original gps antena and i drove today for over hour.
    I do have another antena that i did plug in gor a bit but had same issue.
    Might have to check connections again and try the other antenna
    Jan 2011
    Just a faulty connection all working now.
    Anyone in western suburbs with vcds cable.
    Need a quick coding as my fade is not available?
