Results 1 to 10 of 20
Thread: RNS510 issue
    Jul 2017
    Reservoir
    RNS510 issue
    Hey all. Has anyone experienced a problem with their head unit and the reverse camera unit that after you reverse and then put in drive or park the head unit goes black but stays with the reverse grid lines?
    Camera is losing power most likely.
    Is it a highline camera ie bending guidelines?
    Jul 2017
    Reservoir
    RNS510 issue
    Yes it is bending lines. Not a highline though just a MY13 TSI Passat
    If there camera was losing power would there badge flip down back to normal
    Bending guidelines is a highline camera module (not the named of the car model).
    You need to get a scan of the car for faults codes. That will give some more info about what is failing.
    Jul 2017
    Reservoir
    Oh OK. Maybe it's part of the upgrade because I also have park assist.
    I've not had the car long. Would I just go to VW to get the codes checked?
    No you don't need to go to a dealer.
    Just find someone locally with VCDS or OBD11.
    Jul 2017
    Reservoir
    Well if they it's anyone on here in northern sub melb I'd appreciate the help.
    I was also just looking on ebay and there are a number of the OBD2 units on there for like $40 I wondered if it's get much value.
    No they are not much value.
    They will give you generic OBD codes, but won't be able to decode VW specific ones.
    Jul 2017
    Reservoir
    Ah OK
    Jul 2017
    Reservoir
    Bizarre update the issue has not happened again
