Mine does the same thing 2014 cc and now the camera hardly works anytime. I am trying to find the Vagcom codes to reinstall on the head unit.
Reverse Camera Unavailable error anyone get it on their R36?
Lately been coming up and online ive been reading there is no solution?
It comes and goes but is very annoying.
2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
Yeah on the net it seems there is no solution to this.
have you tried a firmware update?
Not game enough to do a firmware update I have downloaded iso file ready too do, But as I don't have the original GPS map DVD lost it when I moved from Qld. I do have a Sensis map update but I am not sure if the update is also a full version If I needed to reinstall the Nav software.
Hello XXX-1.8T,
It’s a simple RGB camera.
If you don’t have a moving guide lines, there is no camera control unit, which means its directly connected to RCD or RNS.
Its would simply pay off just to pull out and check connection near camera end, as sometimes water might get in there or a simple loose connection.
I believe, some vehicles fitted with camera control unit that take the signal to controller and overlay the moving guided lines and take signal back to radio. I believe that unit is fitted in somewhere in the boot as well.
Or other possibility might be your RCD or RNS have hard reset itself and lost its coding and confused itself.
Las
Hi Las
When the camera is working the lines are there all is working fine.
When this error pops up it doesnt let you access the camera at all.
Its very random so could be something in the boot affecting it.
How do you access the camera to check wiring etc?
Update, I have updated the firmware on my RNS510 reinstalled my updated GPS map and done a hard reset, I have also removed the head unit ( to check the plugs) and also removed the boot lining to check for wire damage, But iam still getting the same error codes when I vcds scan so no rear camera.
What's the exact fault in VCDS?
Fault message.
Friday,09,March,2018,17:00:08:62939
VCDS Version: Release 12.12.0 (x64)
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Control Module Part Number: 3C8 907 441 A HW: 3C8 907 441 A
Component and/or Version: J772__Rearview 0140
Software Coding: 0020008
Work Shop Code: WSC 05311 000 00000
VCID: 285F1E2B9B06C05EFC3-807D
2 Faults Found:
02203 - Audio / Video Input 1
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 125
Mileage: 107571 km
Time Indication: 0
Date: 2003.14.27
Time: 09:40:26
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
03008 - Supply Voltage for Back-Up Camera
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 125
Mileage: 107571 km
Time Indication: 0
Date: 2003.14.27
Time: 09:40:26
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Looks like it's the camera itself.
Cheapest part of the system to replace and quite straight forward.
Just need to remove the boot interior trim and undo the 2 bolts holding the camera in place.
You can even get away with just buying an aftermarket boot release button camera on the cheap.
