Results 1 to 5 of 5
Thread: Retrofitting new steering wheel
    Apr 2018
    NZ
    Is there any other parts needed to retrofit a steering wheel on to a 2011 b7 passat? e.g do I need a new slip ring?
    Depends which steering wheel you're talking about....
    If it's a B7/Mk6 Golf wheel then no, but you'd need to check what steering wheel control module you have.
    If its a B8/Mk7 Golf wheel then it's not that straight forward. Needs a custom adapter soldered onto the steering wheel control module board, and removal of the cruise control stalk.
    Apr 2018
    NZ
    The steering wheel with tiptronic paddles that was from a 2014 Passat and had part numbers 3C8959537D and 3C8959538G. It looks exactly like my existing wheel except for the shift paddles.
    Retrofitting new steering wheel-steering-jpg
    You'll just need to change the coding on the steering wheel control module to enable the paddles.
    Apr 2018
    NZ
    Thanks Kamold for answering my queries
