Results 1 to 5 of 5
Thread: Retrofit xenon lights
    Apr 2018
    NZ
    Is it possible to retrofit xenon lights from a B7 Passat that has them to one that didn't?
    Pacific Paradise QLD
    Quote Originally Posted by Sloanie View Post
    It is possible but not necessarily legal as they have to have washers and auto levellers.
    To do it properly is about $4000AU
    They also have swivels in the light units so dont know how you would go with wiring etc.
    Apr 2018
    NZ
    Thanks for the reply. I was hoping it was more plug and play.
    Aug 2009
    Melb Inner East
    I thought supernova might have an option for a plug and play LED set up, but they've only got those for Golfs.
    Have a look at (for example) Mars Performance's options to see if anything tickles your fancy.
    2007 Passat V6 FSI 4Motion Sedan | Reflex Silver | DBA Slotted Rotors | ATE Ceramics | Pioneer Car Play |
    | Emblem Reverse Camera | R-Line MFSW w. flappy paddles! | Supernova Headlight LEDs & Parkers |
    On the radar: Chrome switches, engine mounts | Living vicariously through everybody else's mods!
    You can just buy a Canbus compatible HID kit which will include HID bulbs, Canbus adapter, wiring and ballasts (i had a Morimoto HID kit in my Mk6 Golf GTI and they were great quality = approx $250 from memory) and they will be fine.
    Not technically "legal" because they aren't factory fitted and don't have the headlight washers etc, but honestly the changes of getting busted are so ridiculously small (especially considering how many bogan chariots (utes) have cheap and nasty HID kits these days which blind the hell out of you as they come the other way) when done properly and when using a good quality kit.
    Link to Morimoto HID kits: Spot light and headlight HID kits
    Canbus adapters: Wire Harnesses : Can-Bus: Morimoto Standalone
