Results 1 to 10 of 11
Thread: Request a Passat owner MY09 or later with Dynaudio system
    Hi All,
    I'm after an owner of a MY09 or later Passat with Dynaudio option.
    I need the part number of the amp under the passanger seat as well as a picture of the connector/harness if possible.
    Can anyone assist?
    Thanks
    Jul 2013
    Hills District
    FYI: MY10 R36 Dynaudio Amp Wont P-n-P
    I bet you have the same amp as mine right?
    Yeah the one with a single connector, not two
    Here are 2 photos from my 2011 Passat wagon with Dynaudio. Can't see any serial numbers without removing from the mount unfortunately & I'm not too keen to take the connectors off either in case the car forgets it has an amp!
    Hope this is of some value anyway.
    Request a Passat owner MY09 or later with Dynaudio system-img_2217-jpg
    MY12 B7 Tdi Highline Wagon | Reflex Silver | Sport Package | Dynaudio | Towbar
    Thanks very much for that 2 plug harness then for Dynaudio, single for VW sound system amp from MY09 on it would seem.
    I don't know if the link below to a guy doing an install on a CC is of any use but I am still keen on finding a way to retro fit the Dynaudio system in to R36 with the single plug.
    My R36 is the same with the later model single connector CBX RNS510 & Accessories: Dynaudio Retrofit
    Thanks I have read his work. I've posted links to a full harness which will allow a fairly painless install.
    Oh ok so this will be possible then ?
    I even spent last night going through forums in Germany reading through everything they had and could not find much info , if anything they would be referring sometimes to the info on our forums or elsewhere to gain a better understanding with certain mods.
    Yeah its totally doable but not a trivial exercise. The whole wiring loom from head unit to all speakers and battery etc needs to be swapped out (or spliced to just replace the amp connectors.)
    Yeah I came across pigtails for the Lear AMP on ebay for $30 I was thinking they could be wired in to the existing loom .
