FYI: MY10 R36 Dynaudio Amp Wont P-n-P
I bet you have the same amp as mine right?
Hi All,
I'm after an owner of a MY09 or later Passat with Dynaudio option.
I need the part number of the amp under the passanger seat as well as a picture of the connector/harness if possible.
Can anyone assist?
Thanks
Yeah the one with a single connector, not two
MY12 B7 Tdi Highline Wagon | Reflex Silver | Sport Package | Dynaudio | Towbar
Thanks very much for that 2 plug harness then for Dynaudio, single for VW sound system amp from MY09 on it would seem.
I don't know if the link below to a guy doing an install on a CC is of any use but I am still keen on finding a way to retro fit the Dynaudio system in to R36 with the single plug.
My R36 is the same with the later model single connector CBX RNS510 & Accessories: Dynaudio Retrofit
Thanks I have read his work. I've posted links to a full harness which will allow a fairly painless install.
Oh ok so this will be possible then ?
I even spent last night going through forums in Germany reading through everything they had and could not find much info , if anything they would be referring sometimes to the info on our forums or elsewhere to gain a better understanding with certain mods.
Yeah its totally doable but not a trivial exercise. The whole wiring loom from head unit to all speakers and battery etc needs to be swapped out (or spliced to just replace the amp connectors.)
Yeah I came across pigtails for the Lear AMP on ebay for $30 I was thinking they could be wired in to the existing loom .
