Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: Replacing rear brake pads causes EPB fault
  1. #31
    Oct 2017
    VIC
    No, it's your ABS module coding which was cleared by replacing the EPB module that's the problem. Always always always take AND save a full autoscan before changing anything from a hardware or coding perspective.
    If you don't have an old autoscan you might need to do a bit of trial and error to find the correct ABS coding. Luckily it's not an MK60EC1 which has a much more complicated coding scheme.
    If you don't have a copy of your original ABS coding try searching online for one from a similarly equipped car.
    Thanks for the guidance mate. I'll have to check my old laptop but unfortunately I'm not holding my breath I'll find an autoscan inclusive of coding. And if I understand you correctly a "similarly equipped car" would need to be a local model not an o/s one?
    I'm also wondering, given the current faults, if it's safe to use the vehicle as there aren't any MIL active? I mean, if I didn't have VCDS I'd none wiser that there is anything wrong with the vehicle.
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
  2. #32
    Wouldn't necessarily need to be local. Just same engine etc.
    If you have no mil on then you're pretty much right to go. But you should be fault free.
    That brake booster fault COULD mean that in an emergency braking situation the abs might not behave as designed.
    Sent from my SM-G960F using Tapatalk
  3. #33
    Autoscan has the coding for all modules.
  4. #34
    Oct 2017
    VIC
    Could there still be a real mechanical problem with Brake Boost Vacuum System?
    Since I o/hauled the right caliper and bled all the wheels I was cautioned about pressing the brake pedal too far (during the procedure) to the floor as this can damage the brake master cylinder seals. The thought here apparently is because normal brake pedal travel (with brake boost) is relatively short pressing the pedal all the way to the floor can distort the seals.
  5. #35
    Sure it's possible but you will get that fault if abs is not correctly coded for the car config.
    Confirm the coding is correct first then if you can't clear the fault maybe that's happened but you'd be unlucky
  6. #36
    Oct 2017
    VIC
    Ok, if I find the old autoscans I'll post asap.
  7. #37
    Oct 2017
    VIC
    Ok, here is one from December 2020
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 36 42 44 46 52 53 56 62 65
    69 72 76
    VIN: WVWZZZ3CZ6P178475 Mileage: 313190km-194607miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: Malfunction 0010
    69-Trailer -- Status: Sporadic communication error 1000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03H-906-032-BLV.lbl
    Part No SW: 03H 997 033 K HW: Hardware No
    Component: P3.2 FSI-EU4 G00 2368
    Revision: --H11--- Serial number: VWZCZ000000000
    Coding: 0000175
    Shop #: WSC 00028 028 00001
    VCID: 356757135C8E40898D9-8060
    No fault code found.
    Readiness: 0110 0001
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 047 J HW: 02E 927 770 AE
    Component: GSG DSG 070 1154
    Revision: 04507000 Serial number: 00000602071105
    Coding: 0000020
    VCID: 1F4B95BBCE72EAD9775-804A
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0667165431
    Coding: 0046535
    VCID: 30696607A3EC65A1DEF-8065
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 BB HW: 3C0 907 044 BB
    Component: ClimatronicPQ46 112 0606
    Revision: 00112021 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 62CDDC4FBD80873118B-8037
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000003835219
    Coding: E1848F0700041A00000A00000F00000000085D435C0000
    Subsystem 1 - Part No: 3C2 955 119
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 00028
    Subsystem 2 - Part No: 1K0 955 559 T
    Component: RegenLichtSens 011 1110
    Coding: 00208933
    Shop #: WSC 00028
    4 Faults Found
    01502 - Bulb for Rear Fog; Left (L46)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 313196 km
    Time Indication: 0
    Date: 2020.12.08
    Time: 19:12:00
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    01519 - Bulb for Back-Up Lights; Right (M17)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 313196 km
    Time Indication: 0
    Date: 2020.12.08
    Time: 19:12:00
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    01500 - Bulb for Fog-Lamps; Right (L23)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 313196 km
    Time Indication: 0
    Date: 2020.12.08
    Time: 19:12:00
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    01517 - Control Module for Trailer/Towing Sensor (J345)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 313196 km
    Time Indication: 0
    Date: 2020.12.08
    Time: 19:25:00
    Freeze Frame:
    OFF
    Voltage: 12.10 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
    Component: 17 AIRBAG VW8R 029 2521
    Revision: 10029000 Serial number: 003A3P1ZPVBF
    Coding: 0012599
    VCID: 2E55787FB9D87351CC3-807B
    Subsystem 1 - Serial number: 6332MSME0F5F0E3BY
    Subsystem 2 - Serial number: 6342MSME0F49367AQ
    Subsystem 3 - Serial number: 6351HTS64IKAP662E
    Subsystem 4 - Serial number: 6361HTS64IKQDAR21
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
    Component: J0527 0015
    Revision: 00005000 Serial number: 3C5953507P
    Coding: 0001111
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 007 0050
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
    Component: KOMBIINSTRUMENT VD1 4240
    Revision: X0033000 Serial number: 00000000000000
    Coding: 0007705
    Shop #: WSC 30081 959 88100
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3640P151190AC5
    Coding: FD82FF4F00020200F100
    Shop #: WSC 12345 123 12345
    VCID: 2F6B657BBED27A59C75-807A
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 313196 km
    Time Indication: 0
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 C
    Component: HALDEX 4Motion 0108
    Coding: 0000001
    VCID: 2D577F73B4DE0849F59-8078
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 P HW: 3C0 959 433 P
    Component: IMMO 043 0364
    Revision: 00043000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 377B5D1B4682B2999F5-8062
    Subsystem 1 - Part No: 3C0 905 861 D
    Component: ELV 024 0370
    3C0905861D ELV 024 0370
    Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
    Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
    Component: Sitzverstellung 0701
    Revision: 00003000 Serial number: 00000000000000
    VCID: 2C5172778FC40141E27-8079
  8. #38
    Oct 2017
    VIC
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
    Part No: 1K0 959 701 L
    Component: Tuer-SG 024 2462
    Coding: 0000951
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 34616A1757F45981BA7-8061
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 RDK 043 0213
    Coding: 01910A0801860E76380494157008DFCE101800
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Subsystem 3 - Part No: 3C0 951 171 A
    Component: Innenraumueberw.002 0508
    1 Fault Found
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 43
    Mileage: 313196 km
    Time Indication: 0
    Date: 2020.12.08
    Time: 19:33:15
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
    Part No: 1K0 959 702 L
    Coding: 0000950
    VCID: 38795E274B9CBDE196F-806D
    Address 53: Parking Brake Labels: 3C0-907-801-53.clb
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000012
    VCID: 214F9343F806DC29411-8074
    Address 56: Radio Labels: None
    VCID: 55A7F793BCCE60896D9-8000
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2432
    Coding: 0000144
    VCID: 3363690B52FA5EB9A3D-8066
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Component: RDK 0391
    Coding: 0161211
    1 Fault Found
    01487 - System Function Test
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 313196 km
    Time Indication: 0
    Date: 2020.12.08
    Time: 19:30:04
    Address 69: Trailer Labels: 1K0-907-383-MY7.lbl
    Part No SW: 1K0 907 383 HW: 1K0 907 383
    Component: ANHAENGERELEKTR 003 0020
    Coding: 0000001
    VCID: 6ADDB46F45B0DF71D0B-803F
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    Address 76: Park Assist Labels: 3C0-919-283.lbl
    Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
    Component: Parkhilfe 8-Kan 004 0011
    Revision: 00004000 Serial number: 82930602501458
    Coding: 0011014
    VCID: 28598E679B3C2D6106F-807D
    End-------------------------(Elapsed Time: 03:12)--------------------------
  9. #39
    Copy your abs coding back from that scan.
    That's what it should be.
  10. #40
    Oct 2017
    VIC
    Yes, I can see the original ABS coding differs from the current one. Do you mean in VCDS go ABS, coding, etc, etc and change just the coding to the previous one being Coding: 0046535?
