Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Replacing rear brake pads causes EPB fault
  1. #21
    Oct 2017
    VIC
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 3AD 035 190 A HW: 3AD 035 190 A
    Component: RCD510USBRVC 003 0003
    Revision: -----001 Serial number: VWZ4Z3P8053234
    Coding: 01000424040010
    Shop #: WSC 00079 790 12345
    VCID: 2B55B2AB4A0539DC86-807E
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 317271 km
    Time Indication: 0
    Date: 2021.04.09
    Time: 01:25:20
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 F
    Component: Tuer-SG 021 2432
    Coding: 0000144
    Shop #: WSC 00028 028 00001
    VCID: 3365AACB5235611CCE-8066
    No fault code found.
    Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
    Part No SW: 3C0 959 433 P HW: 3C0 959 433 P
    Component: RDK 0391
    Revision: 00043000 Serial number: VWZCZ000000000
    Coding: 0161211
    Shop #: WSC 12345 123 12345
    VCID: 377D9EDB464D8D3CF2-8062
    1 Fault Found:
    00667 - Ambient Temperature Signal
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00111000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 177
    Mileage: 317283 km
    Time Indication: 0
    Date: 2021.04.13
    Time: 00:01:04
    Address 69: Trailer Labels: 1K0-907-383-V1.clb
    Part No SW: 1K0 907 383 HW: 1K0 907 383
    Component: ANHAENGERELEKTR 003 0020
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 6ADB77AF457FE0D4BD-803E
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 F
    Coding: 0000144
    VCID: 3467A9D7573B6624D7-8060
    Address 76: Park Assist Labels: 3C0-919-283.lbl
    Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
    Component: Parkhilfe 8-Kan 004 0011
    Revision: 00004000 Serial number: 82930602501458
    Coding: 0011014
    Shop #: WSC 30081 959 88100
    VCID: 285F4DA79BF312C46B-807C
    End-------------------------(Elapsed Time: 02:26)--------------------------
    Disregard the following (previous to EPB control module change) faults:
    012555 - Low Pressure Fuel regulation
    01500 - Bulb for Fog-Lamps; Right (L23)
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
    01517 - Control Module for Trailer/Towing Sensor (J345)
    00132 - Outside Door Handle Illumination/mirror Light Passenger Side
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
  2. #22
    Your ABS is not coded.
    Try setting to 0015815.
    Also EPB is not coded. Try 0000057.
    Then carrying out the required calibrations per the Ross-tech wiki for G200, G201, G85, EPB etc.
  3. #23
    Oct 2017
    VIC
    Thanks kamold, will give it a go tomorrow. Do these require Security Pin?
    Reason I ask - when I went to coding? or adaptation? (can't recall but I think it was in the ABS) there was a specific setting for different types engines but when I selected 3.2 B6 it nonetheless came back with an error message.
  4. #24
    No security access required
    Sent from my SM-G960F using Tapatalk
  5. #25
    Oct 2017
    VIC
    Thanks kamold,
    So, the setting for ABS - 0015815 was accepted and I went on with calibrations as per Ross-Tech Wiki. Check of the parameters against Wiki showed mine were within values given. However, the ABS, Stability Control and the EPC warning lights are still On. The Stability Control switch light (near gear shift) is On and I still can't turn it Off (to get the Stability Control back On)
    The EPB code 0000057 wasn't accepted. I kept trying different settings to get EPB fault cleared as I recall reading that sometimes it may not work straight away and might take 2-3 goes. Eventually, I got the right EPB actuator to work by using the "close brake pads" option (after renewal). After that I was able to clear the EPB control module faults and now the EPB works Ok.
    However, I still have:
    01 Engine showing malfunction: P1653 please check DTC Memory of ABS Controller and a new one P1479 Brake Boost Vacuum System - mechanical failure.
    02 Auto Trans - GSG DSG P1847 please check DTC Memory of ABS Controller
    03 ABS brakes - Vacuum Sensor for Brake Booster (G483) and Longitudinal Acceleration Sensor (G251) No or Incorrect Basic Setting/Adaptation though I think I got that (G251) "fixed" after I saved the faults list. I'll have to re-check that one tomorrow.
    44 Steering Assist - Steering Limit Stop - 005 No or Incorrect Basic Setting/Adaptation (I'll have to re-check that one tomorrow again as I might have also got it fixed)
    All-in-all a progress of sorts but I'm hesitant to use the car "as is" especially with the ABS & Stability Control MIL On.
  6. #26
    Do you have a record of your ABS coding? You need to restore the correct coding.
    That's what's causing the P1479 fault.
  7. #27
    Oct 2017
    VIC
    I persevered PM today and managed to switch ALL the MIL (on the dashboard) off however ... these are the remaining faults as reported by VCDS:
    Address 01: Engine Labels: 03H-906-032-BLV.clb
    Part No SW: 03H 997 033 K HW: Hardware No
    Component: P3.2 FSI-EU4 G00 2368
    Revision: --H11--- Serial number: VWZCZ000000000
    Coding: 0000175
    VCID: 356194D35C417F2CE0-8060
    3 Faults Found:
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 004 - - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 28
    Reset counter: 255
    Mileage: 317285 km
    Time Indication: 0
    Date: 2021.04.15
    Time: 00:18:25
    Freeze Frame:
    RPM: 612 /min
    Load: 23.1 %
    Speed: 0.0 km/h
    Temperature: 85.0°C
    Temperature: 63.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 13.716 V
    005241 - Brake Boost Vacuum System
    P1479 - 008 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 317285 km
    Time Indication: 0
    Date: 2021.04.15
    Time: 00:18:27
    Freeze Frame:
    RPM: 615 /min
    Load: 22.0 %
    Speed: 0.0 km/h
    Temperature: 85.0°C
    Temperature: 63.0°C
    Voltage: 13.716 V
    012555 - Low Pressure Fuel regulation (disregard this one)
    P310B - 004 - Fuel Pressure Outside Specification - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 4
    Reset counter: 255
    Mileage: 317292 km
    Time Indication: 0
    Date: 2021.04.15
    Time: 13:12:08
    Freeze Frame:
    RPM: 1043 /min
    Load: 20.0 %
    Speed: 16.0 km/h
    Temperature: 55.0°C
    Temperature: 20.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.224 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0667165431
    Coding: 0015815
    VCID: 306FA5C7A3235A04B3-8064
    1 Fault Found:
    02543 - Vacuum Sensor for Brake Booster (G483)
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 140
    Mileage: 317367 km
    Time Indication: 0
    Date: 2021.04.16
    Time: 19:09:11
    Everything else is "No fault code found." The only other suspicious one is
    Address 22: AWD Labels: None
    VCID: 55A13453BC015F2C00-8000
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    but I run out of time tonight.
    As for the ABS coding I used the documented basic settings:
    Replacing rear brake pads causes EPB fault-abs-coding-jpg
    Replacing rear brake pads causes EPB fault-other-settings-1-jpg
    the ticks in Bits 3,4 & 5 appeared when I coded Bit 2 for 3.2Lt AWD engine & transmission.
    Replacing rear brake pads causes EPB fault-control-module-jpg
    BTW to remove the EPB faults I used the option "Test Parking Brakes" after which the EPB faults cleared.
  8. #28
    Do you have a copy of your abs coding from before it was cleared?
    That's the easiest way just copy it back.
  9. #29
    Oct 2017
    VIC
    Can I get the coding from the "old" control module?
  10. #30
    No, it's your ABS module coding which was cleared by replacing the EPB module that's the problem. Always always always take AND save a full autoscan before changing anything from a hardware or coding perspective.
    If you don't have an old autoscan you might need to do a bit of trial and error to find the correct ABS coding. Luckily it's not an MK60EC1 which has a much more complicated coding scheme.
    If you don't have a copy of your original ABS coding try searching online for one from a similarly equipped car.
