Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: Replacing rear brake pads causes EPB fault
  1. #41
    Correct.
    Then clear faults and check if you have anything left.
    Sent from my SM-G960F using Tapatalk
  2. #42
    Oct 2017
    VIC
    Correct.
    Sounds pretty straight forward kamold, I shall try this over the coming weekend and report back. Hope one day this post might be of some help to another dedicated VW Passat owner. Now, approaching 318K km ... only 182K km to target mileage.
    But ... in the mean time I still have to learn the best way to get the 1 piece manifold off to replace the broken PCV valve membrane.
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
  3. #43
    Oct 2017
    VIC
    So, it took a while ... but today I've recoded the ABS with the "old" code. Sure enough - it worked. No more ABS fault codes of any kind. I've still got that annoying fault code to do with radio head unit but that ought to be a subject of another post.
    Replacing rear brake pads causes EPB fault-20210510_scan-status-may-2021-jpg
  4. #44
    Good work.
