Results 1 to 8 of 8
Thread: Replacement Shock absorbers Front and Rear
    Feb 2016
    Point Cook, Vic
    Hi looking for recommendations on Shocks to replace the originals on my 2010 125TDI Highline Wagon. Am planning on some very long road trips and as the originals have done 130k thought I should look at replacing before I head off. Looking for comfort and obviously good handling. Any suggestions appreciated
    Dec 2015
    Newcastle NSW
    Bump!
    I have a 125 TDI wagon 2011 with 95k kays and noticed that I get a knocking noise on rear pasenger strut and hitting speed bums at low speed smashes on the bump stops....
    Figured some new struts wouldnt go astray, Koni FSD seem way to pricey was thinking bilstein B4's? I believe oem is sachs? which seem cheap on ebay.de?
    Anyone replaced their oem struts?
    Apr 2012
    Newcastle, NSW
    Yep, Bilstein B4's on front only, rear seemed fine. Also replaced all ball joints and bushings at the same time. Ride and handling really good again. Replaced at 135k klms.
    2012 VW Passat Alltrack 125TDI
    2014 VW Touareg V8 TDI Rline
    I Have VCDS if needed in Newcastle area by anyone.
    May 2010
    Bundanoon NSW
    Quote Originally Posted by daljames View Post
    So never been happy with Passat 130TDI suspension. When rear goes over some bumps, sounds as if spare tyre is loose. Been back to dealer several times. When replacing tyres (Continental with Michelin Sport) tyre place considered rubber mount worn, or out of speck. Claimed it happens even with new cars. Note, I am driving over 2nd to 3rd class country roads.
    Michelin performs better than Continental re quiet running and less harsh over bumps.
    But would really like a more compliant suspension. Car has only done about 52000 K
    So have heard much about Bilstein. Subaru in past years emphasized Bilstein as a big plus!
    Now, as an elderly driver who values comfort over sports capability which shock absorbers would you recommend? Is it worthwhile?
    Alternative is to buy Citroen with hydraulic suspension (The only thing I like about Citroen!)
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
    Apr 2012
    Newcastle, NSW
    Wow, sounds like roll bar links... I'm very happy with the ride/handling compromise. B4's are meant to be more comfort orientated and so next time if i have to do it i'll most likely go for something stiffer. You wouldn't be upset with Citroen C5 for comfort or reliability. But you would be for speed and fuel efficiency.
    Jan 2015
    Melb
    If you want comfort I'd go the Citroen c6 or ds23.
    May 2010
    Bundanoon NSW
    Roll bar links? This could explain why left rear wheel makes a small thump on settling after slowly passing over local shopping centre speed mounds. Looks like visit to specialist suspension mechanic.
    Dec 2015
    Newcastle NSW
    Koni FSD's are marketed for ride comfort in mind, but are quite expensive (around $1k per set I believe)
