The canbus gateway module coding is very short.
its just a string of numbers.
Make a note of this and then when you install the new one, write this string to the new gateway (assuming you are using another 3C0 gateway, and not a 7N0 gateway. )
The other data you need is the 'installation list' which is a list of all the other modules in the car. this needs to be duplicated into the new gateway so that all the modules know how to talk to one another.
