Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Recoding new CANBUS replacement module
    Oct 2017
    VIC
    Each module has it's own coding.
    You are only changing one module (the gateway) so you only need to restore it's coding. Nothing else loses anything.
    Its just that the gateway is the switch that all the other parts use to talk to one another.
    Ok, I can comprehend that. But what is the new/old CANBUS module was used for example in the Philippines or worse in China? Wouldn't that mean that the rest of the code/s are applicable to cars driving in those countries?
    2006 VW Passat Sedan 3.2lt AXZ, FSI 4motion, another milestone - 368K ... and still going
    You're overwriting the coding. It is changing all the settings as may have previously been configured. It's all contained in that coding string. It tells the module how to behave, what's installed etc.
    Oct 2017
    VIC
    Wow, thanks kamold. That is very clever of VW to be able to change all codings to applicable ones just by entering one string AND knowing eg. it's a r/h/d vehicle, it has sunroof, fog lamps, folding mirrors, etc, etc, etc! Thanks for explaining it all and being so patient.
    Oct 2017
    VIC
    Thumbs up
    Hi kamold, I found the last VCDS log and the 19 gateway coding sequence. Cheers
    Recoding new CANBUS replacement module-imag2675-g19-copy-jpg
