Results 1 to 5 of 5
Thread: Rear window electric blind
    Apr 2018
    NZ
    Could a rear window electric blind from a 2011 CC passat fit a normal 2011 passat?
    Albany, WA
    Depends on what is a normal passat, if you mean C then its more likely no but you could probably check out a few videos on your tube.
    Would need programming of button and fitting in innner panels with channels, the motor, wiring. so not impossible but maybe not worth the hassle unless you really really want it and are willing to spend money and do it your self.
    Pacific Paradise QLD
    Didnt even know they had them after 8 years of owning one
    Why would you want one
    Apr 2018
    NZ
    I noticed that a wrecker had a rear electric blind from a cc for under 300 bucks.
    Just thought it would be cool to add.
    Nov 2017
    mandurah WA
    It's not a bad option on the mother in laws camry, only ones I've seen. Might be a mission to retrofit and get working but if your keen then have a crack
