Radio reception??
Apologies if this has been done to death but I couldn't find anything here...
Just received a 2011 V6 Highline sedan and can't for the life of me get the radio stations to tune in, can only faintly hear them when cranked right up loud. Is this common? appears to be an aerial issue...any ideas?
Thanks
Is your rear window tinted? when you tint it, the top plastic panel needs to be removed. The panel exposes the rear brake light, the GPS antenna module and the radio antenna. Uninstall the module and re-seat it on the window, may be it was bumped during tinting. Its worth removing that panel and checking the module regardless.
Awesome...thanks for the heads up Dubber, I'll check it out this weekend.
- You may not post replies
- You may not edit your posts
Forum Rules
