Results 1 to 5 of 5
Thread: R36 Wagon - Driver side rear door exterior handle wont open door.
    May 2011
    NSW
    Hi Guys,
    The other day I discovered that the driver side rear door exterior handle wont open the door.
    The car is unlocked and the door can be opened via the interior handle.
    Before I dive in and start pulling the door apart I thought I'd ask and see if anyone has experienced this issue?
    Regards,
    Red D.
    I did and had to replace the lock assembly, only thing is mine wouldn't open from the inside either intermittently so yours may just be the handle (hopefully)
    Jul 2013
    SE suburbs, Vic
    I noticed the other day when I was trying put on the child lock on the door that there is another lock that looks similar to the child lock. It is located underneath a rubber grommet that has a padlock symbol on it. When I turned it it seemed to lock the outside handle but leave the inside active. Any chance you can play with this and see if it makes a difference?
    Sent from my SM-G930F using Tapatalk
    May 2011
    NSW
    Just a quick update to say that the problem is intermittent and I'm pretty sure that it is an electrical issue.
    Some times it will open and some times it won't.
    Today I unplugged the door connector and inspected the wires after viewing a Youtube video where a couple of wires had broken on an earlier modem Passat. I thought it highly unlikely as the rear doors are not used very often. Nothing observed with mine but I gave the contacts a spray with electrical contact cleaner.
    No improvement. I locked/unlocked a couple of times successfully and then it wouldn't open again.
    Reached around and opened using the inside handle.
    You can feel the difference when you hold the door handle. Definitely a stronger unlatching feel when it is working correctly.
    To be continued.......
    These are a common failure in the golf I assume the lock mechanism is similar if not the same in the Passat. You can buy them reasonably priced from the UK. Replace it before it completely fails as it's a big job if it's stuck closed.
