Originally Posted by
prn31
The 220 FSI engines are identical in the 2010 R36 Passat Wagon or the 2011 V6 FSI Highline Wagon. The only difference I believe is that the B7 (2011+) has a regenerative system that assists the alternator and along with revised gearbox ratios (5th and 6th gears are taller) makes the B7 slightly more economical. The lower weight makes the B7 marginally faster as well.
As for fuel, 95RON is the minimum for both but you would be mad not to use 98RON where you can.
