Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: R36 vs V6 FSI Highline Engine question
  1. #21
    May 2010
    Melbourne, VIC
    Quote Originally Posted by Jesterarts View Post
    Slowly working on the wife to get less "what do you need another fast car for?" type questions.
    Who said anything about 'need'?
    "I've got nothing to wear^H^H^H^Hdrive!"
    Same reason(s) she needs yet another handbag/dress/item of jewellery.
    And then, the final test.... will I fit being 6 foot 5. :p
    I figure I fit into my old 1989 e30 Coupe so I should fit in the passat, right?
    Probably want to avoid a sunroof-equipped car then.
  2. #22
    Aus
    Oh dear. That's not a promising sign...
    I'm just over 6'5" at 197cm so that 10mm may evaporate quite quick.
    Hmm, may have to find a passer at a dealer to sit in soon and check this out.
    Man, there are a lot of 'tall' R36 owners out there! Me being 194cm!
    Well depending on how you adjust your seat, it differs. Setting the seat too high, the rearview mirror blocks your view to your left corner side of your car and also most traffic lights and signs if you're the first at the lights!.
    But I've gotten used to that position for the last 5yrs comfortably!
    Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
  3. #23
    Aug 2007
    Quote Originally Posted by revivor View Post
    I probably should clarify, I am in a B7 Wagon with sunroof. I have seat adjusted to the lowest position and they are electric if that makes a difference. Best to get into similar model stat.
