Results 1 to 10 of 16
Thread: R36 - Time to look for a new battery
    Apr 2013
    Sydney NSW
    Hi guys
    Original battery is giving in I believe, dropping under 12v and tripping the parking mode in my car after turning off the ignition. (Don't think this is normal - I'm no mechanic myself...)
    I also purchased a CTEK MXS 5.0 yesterday for ~$100 off eBay with the 15% eBay Plus discount for the sake of it as I'll be going on a family trip in 2 weeks, not sure if it'll help or not after a recondition.
    Just wanting to see what people are running in their R36 at the moment, and any recommendations of places I can purchase a new battery around Sydney?
    Thanks.
    Going under 12v doesn't on it's own indicate a failing battery. Possibly just that it is being depleted.
    Go to your nearest Battery World and they will test it quickly.
    If you are going to replace it I would recommend an AGM like the factory one that you have as it will last unlike a cheap flooded lead acid which can die after a few years.
    May 2015
    I replaced my original battery last year with a Varta AGM G14 battery from an Ebay reseller. Not cheap at $500, but I essentially wanted an OEM replacement so was prepared to pay the price.
    Biscay Blue MY10.5 Passat R36 Wagon
    Options: Sunroof, RNS510 Sat Nav, Dynaudio, Power Tailgate, ACC, RVC, BT 9w7, Tint and Factory Towbar.
    Atlantic Blue MY19.5 Golf GTI
    Options: Luxury Package and Sound & Style Package.
    Apr 2013
    Sydney NSW
    Had NRMA drop by , and apparently the battery dropped to around 8volts when cranking. Not too sure if thats thorough enough?
    Option of $425 for their AGM, alternatively can look at purchasing a Varta G14 for a bit over $500.
    Thoughts?
    Yep 8v is too low.
    $425 for an AGM is pretty good value.
    Apr 2013
    Sydney NSW
    Yeah seemed like a reasonable deal, just unsure about the quality of their batteries though. Slightly leaning towards a Varta.
    Jul 2013
    Hills District
    Id say go Varta!
    I would say go with the Varta as the OEM one is, and mine is still going after 10 years.
    However I've now had 2 Varta flooded lead acid batteries both fail just outside of their 2 year warranty.
    So now I'm not so convinced that the retail Varta and German OEM Varta are comparable.
    If it's AGM from a known manufacturer I would say you'll be Ok.
    Apr 2013
    Sydney NSW
    Thanks guys ended up buying a Varta G14 last night on eBay - took advantage of the 10% discount + cash rewards so it ended up costing ~$90 more than NRMA.
    Delivery was made today (kudos to Trackwarrior for sorting it out so quickly). Also bought a CTEK MXS5.0, would it be recommended to run a charge on the new battery with it prior installation?
    Julian the battery is made in Germany, would this still be the "retail" Varta's you're referring to?
    If it's AGM you'll be fine.
    The Vartas that I've had fail were flooded lead acid.
    I wouldn't recommend anything but AGM in anything other than a cheap runabout.
