Results 1 to 3 of 3
Thread: R36 Sport Mode
    Nov 2014
    New Zealand
    R36 Sport Mode
    Does Sport Mode do anything other than change gears at higher revs?
    2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
    2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
    DSG shifts are faster in sport mode as well as at different shift points.
    Dec 2014
    Many years ago I bought a DSG tune which was a Harding Performance DQ250 driveability upgrade. After the software upload, the DSG held gears for longer in D and for less time in S. In D 6th now engages only above 70 kph which is nice.
    However I still find S holds low gears for too long when there's no throttle input. I mean it's nice to have some engine braking but it's a bit excessive. Are there better tunes available?
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
