Should be a straight swap. Also depending on if electric or not. There is a chance the airbag plug may be different too.
Hi all,
Just wondering if 2008 R36 seats will bolt into a 2006 passat?
Or if not, are there other options for aftermarket seats that are not crazy expensive ... looking for better support and comfort.
cheers,
Jon
DARKHORSE DEVELOPMENTS
BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. 0420839266
BRISBANE/GOLDCOAST/IPSWICH
www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
thanks mate I'll give it a go.
No probs. Physically the same mount points.
You might have to swap the airbag plugs. It's quickest / easiest to cut the wires 100mm back from the plug and solder / heatshrink.
The little black plug for the seat belt sensor should be the same.
Where did you find the seats?
I am looking to sell my 2008 R36 front seats and put some other lightweight hugging seats in. Has anyone ever tried this ? I had a look under the drivers seat and there is a whole lot going on such as wiring/looms, control unit, mechanisms etc. EVO 7 or 8 seats may be a possibilty.
