Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: R36 PCV Valve Replacement
  1. #21
    Hunting revs at idle is the classic symptom.
    Sent from my SM-G960F using Tapatalk
  2. #22
    bad fuel trims will also be apparent, due to the unmetered air.
    Yes if you check with diagnostics will be evident.
    When I had a leank due to the upper intake not sitting flush the trims were way out.
  4. #24
    Albany, WA
    Ok, thanks guys.
