Results 11 to 20 of 21
Thread: R36 parker light replacements?
    Jun 2009
    Oh cool. Thank goodness!
    Nice one
    Sent from my LG-H815 using Tapatalk
    Mar 2016
    Qld
    I'm using these ones:
    Buy Products Online from China Wholesalers at Aliexpress.com
    They match the DRLs and 6000K HIDs I have installed.
    I hate the yellow filament globe look personally.
    Hi kamold,
    I ordered some of these to replace my parkers and they arrived today.
    The led's measure 3.5cm whereas the globe that's being replaced is 2cm. When I tried to fit the led, it was too long and was pushing against the parker light housing.
    Did this happen to you?
    Not devo by any means as a very low price for the led's, but am keen to get the right ones.
    Yes they are longer and do end up well I side the housing. Mine still fit however so I'm happy with them.
    Sent from my HTC One_M8 using Tapatalk
    Hey Cof ,
    I used phillips led's and they fit perfect ,nice look as well.
    If you don't mind spending a little more and putting some quality led's in your R36 ...
    Check out the pic's I uploaded here ....
    LED Parkers for R36 Install (WIth Pics)
    Link to the Drl bulbs?
    Quote Originally Posted by Vr32wa View Post
    http://s.aliexpress.com/UraaMfiy
    Sorry dead link,just type drl vw in the Aliexpress site you will find them.
    Mar 2016
    Qld
    Quote Originally Posted by Heinrich R36 View Post
    Hey Cof ,
    Thanks Heinrich R36, I gave the ones I had another go however one came off and almost fell in to the light bulb cavity...a real pain to get it out and took me ages.
    Anyway I haven't had a chance to look around for others however I notice you've used a canbus control unit with the phillips globes, how do you install the control unit?
    Quote Originally Posted by cof View Post
    No probs,
    The canbus units are very small and come with 3m double sided foam sticky strips to attatch the unit anywhere.
    There is actually enough room to mount them inside the rear of the headlight where the access panel covers.
    I will take some pics tomorrow to give you an idea how to fit them neatly.
    No probs,
    Here is a pic inside the rear of the headlight housing with the canbus unit connected and stuck to the side.
    Good fit they were.
