Thanks for the detailed instructions and the links - I just picked up an r36 recently and this is a great help as I undergo a similar exercise on my car
Well,
As promised, my next instalment in the LED upgrading of our R36 is upon us. This time around it is LED puddle lights. I purchased these from the following website ( 2X Error Free LED Side Mirror Puddle Light VW Golf 5 MK5 MKV Passat B6 Jetta EOS | eBay ). Now I was a little dubious in spending that sort of money but it actually was cheap compared to some ebay store prices. Now the install was pretty easy really. All you do is gently push the mirror forward towards the front of the car. It will let go and you will see the end of the puddle light along with a little torx screw. All you do is unscrew it and get a small flat head screw driver and pry open the light using the vertical edge closest to the front of the car. Be gentle and the light will pop out. The original light is a T10 bulb pushed into the housing. Simply pull the rubber stopper away from the light housing and you will see the T10 bulb sitting there in its housing. Simply remove bulb and push the end of the new LED assembly into the socket. Then push the wires into the mirror housing and push the LED assembly back into the mirror and replace the torx screw. Very easy mod. Probably took 3 minutes per side. The results are very impressive. I would say that the light output is about three times brighter than the standard yellow bulb and it is very white. If you wish not to install the LED's you could simply buy blue T10 bulbs and you would get a whiter light than standard but you won't get the light output. Anyhow, some pictures are attached and they really don't do it justice. Any questions, please ask.
Ps. Ignore the dirty car. Haven't had a chance to clean!
NickZ
Former ride: MY07 Black Polo GTI
Current: MY09 Blue Passat R36 Wagon
No problems. Next installment will be rear number plate LED's. Will be interesting for that one
Hey snerlo let me know when you do the tail lights. I need to do mine as well. We can do them together. 2 heads are better than one. Just ask all our Tasmanian Brethren.
Rising Blue MY10 Passat R36
BLACK '97 Mk3 GL 2.0L
White '82 MK1 Cabrio 1.8L
Vice-President - VWDCQ (VW Drivers Club of Queenland inc)
Check out my new thread mate
Thanks for the guide Snerlo. Makes it a lot easier.
Puddle lights arrived today and were easy to install. Only problem was one of the wires had come loose so just re-soldered it.
Looks great.
2010 Passat R36 - Icelandic Grey / BT / MDI / Power Tailgate / RVC / Cargo Management System / 19" Lugano Wheels
2005 35th Anniversary 350Z - Ultra Yellow / Stillen True Dual Exhaust / Motordyne MREV 2 and Plenum Spacer
Don't know if anyone has tried yet.... Just wondering if this was to be done on a B7 Passat, would the whole mirror need to be removed? I've had a look at mine, looks like surgery!
MY11 B7 Passat 125TDi Highline
Pearl Mocca Anthracite | Electric and Heated Leather | Folding Mirrors | Sunroof | Adaptive Lighting Package | Footwell Lighting | Park Assist 2 | Lane Assist | RNS510 | R36 Pedals | Scirocco MFSW | Front Lip | 20" Suzuka Wheels | H&R Springs | De-Badged | VCDS Mods | Alpine Mono and 8" Subwoofer
