Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: R36 Front right dipped beam (xenon) not working.
    Mornington Peninsula, VIC
    They are d1s
    I was referring to blergen's question about the B7, my B7 definitely has D3S bulbs, I have the box they came in. They must of changed to D3S at some point.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Feb 2015
    Straya
    Thanks MIG, yes definitely a D3S bulb on my B7. I'll give it another go.
    Cheers.
    Quote Originally Posted by MIG View Post
    Ah ok sorry was referring to the thread title.
    Jan 2017
    Figure I'll jump onto this thread - my lights are working, but I'm getting an error thanks to my high beam on the righthand side. I understand the xenons are always on 'high' and have a reflector that moves out of the way when high beams are active. Apparently I have an electrical fault stopping this from happening, so only my left high beam will turn on.
    I understand it's not a serviceable part and that you need to replace the entire headlight, or that it's sometimes the controller that needs replacing.
    Fault code 02499 - Electrical error in circuit
    Any ideas?
    That code is for a Right Low Beam Reflector Motor (V295)
    Open up the back cover of the light and check if any of the wires look damaged or frayed; I have heard of these having the insulation fail and shorting out.
    Jan 2017
    Thanks MIG, I'll check that out
