Yep. Sounds exactly like the other videos when I try to record it but significantly better in real life. I haven't been able to do the wiring yet, only the physical install, so for now the valves are permanently open. It is a bit droney when under load at 2-3k rpm but easily fixed by switching gears. I am getting constant looks, it sounds like a Lambo if you hit it and shift right, and a V8 on idle. Am amazed by how good it is.
